Flapper's avatar
Flapper
Do I need a battery box??
I understand the purpose of them - contain spills, and provide ducted venting of any outgassing of hydrogen.
In my Jayco 5th (HT 26.5 RLS) there is currently in the compartment a group 27 box, with a vent hose to the front of the trailer.
I want to change out to two 6v Costco batteries.
Space is pretty tight (22" x 10.5") in the compartment (height is fine). No commercial single/double 6v battery boxes will fit. Batteries each are 10.25" x 7".
Designing and building a wood box(s) (coated or lined inside) is possible, but still is a bit of a challenge to figure out how to get it in and out, either with or without batteries in it.
I'm thinking maybe more of a custom tray to install and strap them down.
Rather than a ducted vent, just leave the current 3" louvre and hole that is cut in the front side of the compartment as the ventilation area. I'm not really sure how much the current factory system actually vents anyway, as the louvre is on the front of the fifth. It seems that there would be a lot of air ramming back into the current ductwork as I drive, preventing the escape of gases.
Do I need to be more proactive in ventilating - dedicated ducts, etc?
How about acid/fume protection? I could line most of the area with PVC shower pan liner to help protect. But then I keep thinking about my various cars (and boat) that all just have the battery tray mounted, with no particular concern about protecting the surrounding parts and pieces.
Any voices of experience on this? What is your RV like for battery storage, or what have you done that works over the long term?
  • Yes a vented battery box(s) is needed inside the basement compartment of your 5vr.
    I have dual batteries.....2 boxes both vented in front compartment...one each side
Having RV issues? Connect with others who have been in your shoes.24,309 PostsLatest Activity: Sep 05, 2025
