valhalla360
Jun 13, 2022Navigator
What is the charger and how long were you running the generator?
First morning 60% to 85%, is 25% of 200ah or 50ah. A 50amp charger should do that in around an hour.
Second morning 50% to 70%, is 20% of 200ah or 40ah. Should take 20% less charge time to get there.
Did you per chance run the generator for 1:15 the first time and 1:00 the second time?
You generally won't get to 100% charging with an hour or two on the generator (even if the charger puts out enough amps). Lead-Acid batteries start reducing the charge acceptance around 70%. At first it's a minor reduction. By the time you get to 80-90%, they accept far lower amperages, no matter how big the charger is.
If you will be boondocking another option is to get something like a 100w portable solar panel.
- Run the generator first thing in the morning to get up around 80-90% (an hour or two).
- The solar panel will peak around 8amps mid day but it will do so over several hours and top up the remaining storage.
Of course, if you do a lot of boondocking, a large permanently installed solar array is a nice option but it brings it's own set of costs/complications.
