louiskathy
Aug 09, 2013Explorer
I'd level it out. Give it a day to settle and then see if it works.
I wouldn't call it toast yet.
You said that you shut everything down except the fridge... well, if you shut the electric off and it was running on propane... it ran out of propane.
Also, the fridge NEEDS 12 volt to work. So if your house batteries ran dead, they need to recharge awhile. Plug the rig into shore power and let the batteries charge.
And the fridge has it's own fuse at the back of the fridge. (Not the regular control panel on the wall with all the other fuses.) This you have to get to from the OUTSIDE of the rig. At the back of the fridge is an outside vented door. Remove that and look for a black plastic box at the base of the fridge. Inside you will find the fuse I've talking about. If it's fried... replace it.)
