campingwiththor's avatar
May 07, 2018
Do I need plumber tape or other?
Going to replace a kitchen sink faucet today.
When hooking up the hot and cold lines... do I use a plumber tape? if so- which one?
thank you!
CWT
  • Be careful when using the term plumber's tape. It used to almost exclusively refer to the galvanized metal, plastic or copper strapping with holes in it used to hang pipes. The term has been co-opted and now refers to both the original stuff and to teflon pipe sealing tape. Confusion is guaranteed.
  • I replaced a kitchen sink faucet in a camper once before. I can be a very tricky job. In my case, the undercounter footprint of the original unit was a lot smaller than the footprint of the new unit. I have to do some fancy chisel work to cut away some parts that were in the way.
    If you have rigid plastic connections now, you will likely want to attach flexible ones to the hot and cold so you have playing room to make them attach to the lines in the rig easier.
    Depends on the fittings, but never hurts to have a roll of 1/2 inch plumbers tape handy.
