opnspaces's avatar
opnspaces
Navigator III
Jan 22, 2022
Do I need the ground lug to connect my new converter charger
After much deliberation I finally bought a new 3 stage charge converter for my trailer. Original post
It took a while to decide, but I finally settled on a deck mount Powermax PM3-45LK 45 amp converter charger. Powermax
Now for my question that hopefully someone can shed some light on. The unit has a positive and negative attachment point for the batteries. There is also a grounding lug that I am supposed to run to the trailer frame. Can I run the unit without the grounding lug attached? Since it has a standard 3 blade 120v plug I was curious if I can use the unit sitting on the floor of my garage to charge the batteries out of the trailer? My initial thought is yes I can. But in the back of my mind I seem to remember a post about the importance of running a separate ground wire from the grounding lug to the frame and not just connecting the two grounds together at the battery. Do I remember that right or did I imagine it?
  • Be sure the garage grounding rod is copper and be prepared to fall over and faint when you see the price. :B
    OK Couldn't resist. Not sure why the ground lug for the trailer is needed since the plugs ground wire is also bounded to the frame, but perhaps some electrical standard safety practice. Perhaps the lug could also be for suppression of some electrical emissions.
  • There should be a ground bus around someplace to connect the converter chassis ground
  • You have to drill a hole in your garage floor and drive an 8-foot grounding rod down into the ground.
    Just kidding, you will be fine without the extra ground wire.
Having RV issues? Connect with others who have been in your shoes.24,308 PostsLatest Activity: Sep 03, 2025
