- BumpyroadExplorer
RKW wrote:
Bumpyroad wrote:
Ron3rd wrote:
I think it might have some mechanical effect if you don't put too much water in the tank as the cubes float on the top.
exactly, if you add too much water, all they do is bob along.
bumpy
In the video in the OP, NO water was added. There were at least two cameras providing a view to the process. Within moments, the ice cubes were soft edged chunks colliding ineffectively against the poo pile and poo smears. In a RV black tank the same thing happens.
my friend removed a "pile" using marbles slamming around. no rough edges, no chemical reaction, just pounding. of course he had another issue for quite a while until they all made it to the drain.
the best way to get rid of this pyramid is to buy a tank sprayer, drill the mounting hole for it, poke a pressure washer nozzle in the hole and blast away. after pile is loose, mount sprayer. use the sprayer every time you dump tank.
bumpy - RKWExplorer II
bumpy
In the video in the OP, NO water was added. There were at least two cameras providing a view to the process. Within moments, the ice cubes were soft edged chunks colliding ineffectively against the poo pile and poo smears. In a RV black tank the same thing happens. - MEXICOWANDERERExplorerTry using NO chemicals when the rig is parked. Add 3 or four packages of live YEAST made for septic tanks. Tank has to be nearly full of water and weather has to be warm. It proved to be slow but thorough. And smelly.
- BumpyroadExplorer
bumpy - Ron3rdExplorer IIII think it might have some mechanical effect if you don't put too much water in the tank as the cubes float on the top.
- BumpyroadExplorer
RKW wrote:
No, of course it doesn't work. Within seconds ice loses what little abrasiveness (if any) it has. Besides, remember your high school chemistry class basics that states chemical reactions are more efficient at higher temperatures? True cleaning is a chemical reaction. If you want to clean your tanks, dump in laundry detergent and hot water and drive around on a hot day.
it is NOT abrasion, it is supposed to be a chunk of stuff sliding around and slamming into the other stuff adhering to the sides/bottom of the black tank. have somebody drop a 10 lb. block of ice on your hand and tell me it isn't felt.
and using soap on a dirty surface is not a chemical reaction.
bumpy - crcrExplorerIt worked for us. Our black tank indicator was stuck on full for some time, even though it was empty. So we tried a bag of ice before a 400 mile drive, and now the sensor reads correctly.
- N-TroubleExplorerI've had good success with ice in the tank and so have many others. 3-4 bags is what I use. DO it about twice a year and make sure its before getting ready to run down a windy road. While it may not clear all the sensors it does help break down the turd teepee underneath the can. Dump the tank when I get home and it comes out looking like pooh soup.
Try it, you might be surprised... - RKWExplorer IINo, of course it doesn't work. Within seconds ice loses what little abrasiveness (if any) it has. Besides, remember your high school chemistry class basics that states chemical reactions are more efficient at higher temperatures? True cleaning is a chemical reaction. If you want to clean your tanks, dump in laundry detergent and hot water and drive around on a hot day.
- Parrothead_MikeExplorerBack in '03 when I purchased my used '01 Cardinal I soon found out that the previous owners, who never pulled it themselves and kept it set up at a campground all the time, kept the black & gray valves full open all the time. As you can imagine, there was a pyramid of poop in the black tank. Someone on this site recommended the ice method to break up the pyramid of poop. I tried it, but got minimal results.
Then someone, also on this site, recommended that I use liquid Calgon water softener. I poured about a cup or so of Calgon into the 2-3 gallons of water I put into the black tank when I put the deodorizer packet in prior to leaving on a camping trip. This, over time, did the trick of removing the great pyramid. I use one of those clear plastic connectors when dumping my tanks so that I can see when the black tank fluids run clear and think the Calgon helps to break down the solids and paper.
In regard to the sensors, I'd say that it helped to keep them clean, but over time (I've owned it for 11 years now) I admit that the sensors are not totally reliable.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
