jfkmk
May 21, 2015Explorer II
I've had 4 fuel pumps fail (I generally keep my vehicles until the 200k mark) on vehicles ranging from Ford to GM to Chrysler. They've failed while moving, sitting at a light to simply not starting one day. None of these failures gave any warning whatsoever. I admit I've never checked the pressure at the fuel rail, so I can't comment on that, but in each case they ran perfectly up until the moment of failure.
If your vehicle has more than 100k on the od, it may be a good idea to change out the pump. You'll probably spend a little less than you would being at the mercy of whoever you get on the road, and you certainly won't be stranded.
Whatever you do, buy a good quality pump, don't skimp! The price to replace is all in the labor. I've never had the fortune of having a vehicle where I didn't have to drop the tank to replace the pump.
I've also heard that if you don't run the tank empty you'll extend the life of the pump.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
