jfkmk
May 21, 2015Explorer II
BurbMan wrote:jfkmk wrote:RJsfishin wrote:
The guy that changed mine said that not changing filter often enuff will shorten a pump's life,......
I would kind of question that. The filter is downstream of the pump and wouldn't have prevented the pump from becoming clogged. Also, there are many newer vehicles that are designed with no fuel filter. My civic has no fuel filter and is on the original fuel pump at 165k.
It's not that the pump becomes clogged, the clogged filter creates too much back pressure and makes the pump work harder.
Duh! My bad, Burbman, I certainly didn't think that one through. Thanks!
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
