pnichols
May 28, 2015Explorer II
jfkmk wrote:
At issue is you have two pumps working at the same time wearing out at the same rate. Your second pump might not fail at the same exact time but it would be close. You'd be better off cost wise replacing the pump at a given mileage interval.
Two wearing out "at the same time" is not going to happen. Take a quick study of the probability statistics concerned with the failure of electro-mechanical devices and it'll show you that: The probability of one electro-mechanical item failing - mulitplied times the probability of another identical electro-mechanical item failing while in service along with the other - equals the resultant probability one must live with of both "going bad at the same time". These two probabilities multiplied together make for a very, very, very small probability of paralleled in-tank fuel pumps ever failing at the same time and leaving one stranded in a busy intersection or out in the middle of nowhere. Of course along with parallel in-tank fuel pumps one should have some kind of indicator on the dash telling when the first one to fail has, indeed, failed -> hence you're now relying on only one of the two in-tank fuel pumps and bettter do something about it.
jfkmk wrote:
The newer serpentine belts will go 150k plus miles and require releasing the tension at one point. It took me less than 5 minutes to replace it on my SUV and that was from opening the hood to closing it.
This seems to NOT be the case for the V10 engine in the common Ford E350 and E450 cutaway van chassis under a lot of Class B/C motorhomes. The mechanic that last changed mine in our rig (per my request at 45K miles for preventative maintenace) needed a special tool to do it (I think it had something to do with holding back, and/or maybe completely removing, the tensioner pulley to install a new belt). Plus ... I looked quite some time under our motorhome's van nose hood on our E450 and it's packed in there. I could not get near it's serpentine belt without removing the radiator shroud and then probably having to lay on the ground underneath the engine to snake a new belt up and around all the bottom sides of the various pulleys. I wouldn't want to have to do this out in the desert somewhere. Nevertheless, I carry a new spare serpentine belt anyway, just is case I can figure out how to replace a broken one should I have no choice - since one is entirely dead in the water when a serpentine belt breaks. At least with the old multiple belt design if, say, the alternator belt broke ... I could keep on driving with no alternator ... since some motorhomes can go a long distance running off the engine battery in conjunction with the coach battery(ies) powering all the engine functions (like ours can using the emergency boost switch).
By the way, a fuel pump tank access port will not be of any help in getting to the fuel pump in a motorhome ... unless the motorhome builder installed an in-floor access port directly above the tank access port.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 09, 2026
