- BurbManExplorer IIGM pumps usually fail right about 100k miles. A good rule of thumb as indicated is to not run the tank below 1/4, the pump uses fuel to keep it cool. Sometimes a failing pump will result in a rough idle or a stumble at idle. Not always, but sometimes. Some lucky guys like me have TWO fuel tanks and EACH one has has an in-tank pump....
If the pump on the '98 is original, I would replace it as preventative. - RJsfishinExplorerThe guy that changed mine said that not changing filter often enuff will shorten a pump's life,.....said mine was 1/2 plugged, even tho it never missed a lick on an 8 mile 6% grade. And that was a 26 ft 454 w/ 56K miles.
- monkey44Nomad IIHad an '03 Sierra 4x4 went 214,000 on original pump - traded it.
Had a '99 Safari AWD that had two go after about 75,000 miles each ... 196,000 Total miles ... both pumps quit working with NO warning
Never can tell which pump will last and which won't. We generally keep our fuel tanks over quarter tank ... just as a policy.
DOn't know if that helps anyone? - jfkmkExplorer
RJsfishin wrote:
The guy that changed mine said that not changing filter often enuff will shorten a pump's life,......
I would kind of question that. The filter is downstream of the pump and wouldn't have prevented the pump from becoming clogged. Also, there are many newer vehicles that are designed with no fuel filter. My civic has no fuel filter and is on the original fuel pump at 165k. - Yes, they do. The symptoms are this. You drive and the Vehicle is at running temp. You shut it off and try to start. It turns over but does NOT fire up. After an hour or so, you attempt to start the vehicle and it fires right up. Odds are it is a defective in tank fuel pump. Doug
It's not that the pump becomes clogged, the clogged filter creates too much back pressure and makes the pump work harder. - jfkmkExplorer
Duh! My bad, Burbman, I certainly didn't think that one through. Thanks! - MEXICOWANDERERExplorerOff-topic, but the '02 Silverado that I purchased a replacement Delco pump for, ended up getting a pump plus the fuel level sender as an integrated part.
- landyacht318ExplorerOne day I noticed my fuel pump was a a lot louder than normal.
About 150 miles later, with 25+ gallons of gas in a 35 gallon tank it quit.
I was in Baja. A local farmer helped me drop the tank just off of Mex1.
My buddy has a Chevy Astro with a pump just as loud as mine was before failure. Been just as loud for 10K miles now. - HalmfamilyExplorerOur pump failed without notice on Chevy Venture several years ago. I had just filled the fuel tank went home go get something and made to the end of the road and the van died. $800 later I was on the road again.
The mechanic said to not overfill the fuel tank, stop filling when it the pumps shuts off. Don't know of that had anything to do with the failure or the fact the van was a POS.
Having RV issues? Connect with others who have been in your shoes.24,190 PostsLatest Activity: Jan 19, 2025
