- Timmo_Explorer IIYes with air you must go to each spot and open the valve/faucet (just as you do with pink), starting with the water heater (good time to replace the anode). No different than blowing air through the sprinklers...lol, could you imagine using pink for sprinklers?
If you want to use pink, please continue; just some of us are able to get the job using air (at no additional cost and no difference in the time to get er done). - Dave_H_MExplorer III pay whatever it costs for two gallons of pink on sale. ;)
- ReneeGExplorer
Timmo! wrote:
Using the air compressor is easy to winterize RVs and the sprinkler lines under ground in the yard. Just make sure you have an inline water/oil filter.
One of the things you do when you live in places that dip in the teens at night.
When using only air, make sure you open your toilet valve. How do we know? We've forgotten a couple of times and once we were lucky, so now we use the pink stuff to ensure it's all out. Same with the spray head at the kitchen sink! - RAMwoodworksExplorer
Good call on the air!!! Only place I used the pink was in the P traps.
I don't trust the air alone. Too many dips and bends in the lines where the water could settle into. We regularly get below zero so I use the pink stuff. - ferndaleflyerExplorer IIIGlad I live in the South. Even if it did get that cold here I would put heat in the house and all my water things are in the same basement compartment so heat it also. This has always worked.
- Cummins12V98Explorer III
Good call on the air!!! Only place I used the pink was in the P traps. - Timmo_Explorer IIUsing the air compressor is easy to winterize RVs and the sprinkler lines under ground in the yard. Just make sure you have an inline water/oil filter.
One of the things you do when you live in places that dip in the teens at night. - ReneeGExplorerSame here, we do it ourselves. Even with me helping hubby, it takes us about 20 minutes, but still. Once you learn how to do it, you'll end up doing it yourself.
- It's so easy to do I can't imagine paying someone to do it.
I'm not as good as Jax, it takes me twice as long.. ;) - JaxDadExplorer IIII winterize my 2 rigs probably a dozen times a year, I have a couple of air compressors and a the 5 minutes it takes to do it.
Even if someone came to my place to do it, instead of the inconvenience of going somewhere I still wouldn’t have them do it.
Having RV issues? Connect with others who have been in your shoes.24,367 PostsLatest Activity: Mar 10, 2026
