wing_zealot
Jan 26, 2015Explorer
Lighting the lane next to you is probably illegal; if not it should be. Yes it is feasible, you would have to use relays. Not knowing anything about what you trying to put lights on, what the specifics of the lights are, where you're mounting them, etc. I would recommend if you had to ask the question, you probably need more personal advice from a qualified tech.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
