Yá'át'ééh; (Hello) I've posted this on a couple of other forums a few months ago and only found 1 or 2 RV owners with similar setups. Hoping there may be some on here. Keystone has modified ...
OK, you may have already tried this, but how about setting it up to winterize, starting the pump and then flip the lever to fill? The RV pump should keep on pumping and the water will be diverted to the FW tank.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 28, 2026
