Yá'át'ééh; (Hello) I've posted this on a couple of other forums a few months ago and only found 1 or 2 RV owners with similar setups. Hoping there may be some on here. Keystone has modified ...
I don't have the same setup, but I sometimes need to fill from a 6 gallon jug and it is too heavy to pick up to the gravity fill. I bought a cheap water pump that mounts on an electric drill and use a battery operated drill. Short hose into jug and short hose into fill spout. While I can't say for sure it would work for you, it wouldn't cost much to try. Got the pump from Harbor Freight Tools.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 28, 2026
