Wayne_Dohnal
Mar 27, 2014Explorer
The Honda 2000 was never intended to run a 13,500 BTU AC. Do the math, on a really good day, at sea level, with absolutely nothing else on.... maybe. We do get the occasional "mine did it just fine" post but the numbers say otherwise. If you want to screw up your AC run it with less than the ideal voltage.When the 13,500 btuh air conditioner plus whatever else is on draw less than the eu2000i rated load, and the voltage is over 120, the numbers are perfectly happy. In my case, the 13,500 Brisk Air pulled 1,415 VA, comfortably below the eu2000i continuous rated load, allowing the power converter to also run if the battery wasn't heavily discharged.
