DougE
Nov 07, 2017Explorer
If you have a freeze of limited duration and especially if you have some water usage during the freeze the hose will likely not freeze. The insulation slows the loss of temperature but does not ultimately prevent freezing. If you want to prevent freezing for long term usage you need to put heat tape under the insulation. It is readily available at RV and Big Box Home Improvement stores.
