WILDEBILL308
Nov 07, 2017Explorer II
DAS26miles wrote:
expecting temp to drop to 25 tonight. Have full hookups and usually I unhook freshwater hose and stow in heated compartment. But I see one or two using foam pipe insulation around their hoses, does it work? I have a few extra that I place on the edge of my slide out to prevent my heading my head.
Fill your water tank then disconnect and drain the hose and store like you have ben doing. I would also shut your gray water drain if it is going to be cold for a while. Water running through the sewer hose will build up ice and plug the sewer hose. Ask me how I know. It also takes a long time to get it thawed if it marginally warms up. I would also add some extra heat in the wet bay if it will be cold long. At least a 75wat regular light bulb. I have a small ceramic heater with a fan for when it gets really cold.
Bill
