valhalla360
Jul 07, 2021Navigator
mr_andyj wrote:
Extreme heat speeds up the chemical reaction inside a battery and causes an increase in the self-discharge and plate corrosion. This leads to sulfation which can cause irreparable damage to the battery.
For each 10°F rise in temperature, the life of a sealed lead acid battery is cut in half. Therefore, if a battery in a stationary position that should last for 4 years at normal temps, would last 2 years if exposed 92°F and even less if exposed to typical desert temps of 106°F.
And of course, this is talking about long term effects.
I help out our Kuwait office and 7 months of the year triple digit temps are normal. Mid summer 120-125F (actual temp not feels like) are not uncommon. The guys I work with tell me 2yrs out of a starting battery is doing good.
Assuming the OP is talking about the heat wave in the NW that is likely to last only a week or so, it's unlikely to have a measurable effect.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 26, 2026
