wa8yxm
Jul 08, 2021Explorer III
First depending on the battery type keeping them INSIDE can lead to various levels of Disaster. Up to and including death by a couple different vectors.
Wet cells (Both flooded and maintenance free) most dangerous
AGM a bit safer
And LiFePo4.. well likely the safest but the jury is still out.
With the exception of LiFePo4.. I strongly recommend against indoor batteries. }
With those.. I do not recommend it but.. as I said jury still out.
Now to the OP's question:
Yes heat affects the batteries.
THIS article may confuse some so I'll summerize
Higher temperature means the battery can store more amp hours
But it also means you will need to replace the battery sooner perhaps in 7 years instead of 9)
Lower temps (Very low) are not good either
Source Document found by a Google Search
AGM a bit safer
