MrWizard
Jun 30, 2014Moderator
to answer the OP question
No.. as along as the generator is big enough (enough KW), it is going to maintain voltage and NOT hurt the A/C
if the generator is too small, either the A/C will stall or the generator will overload/trip breaker/stall engine
the MOST often occurrence of A/C damage is extensive runtime with low voltage shore power, something that does NOT "naturally happen" when using a generator
a generator under so much load it has "low voltage" is going to "fail" in some manner, as noted above
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 28, 2026
