valhalla360
Jul 01, 2014Navigator
MrWizard wrote:
to answer the OP question
No.. as along as the generator is big enough (enough KW), it is going to maintain voltage and NOT hurt the A/C
if the generator is too small, either the A/C will stall or the generator will overload/trip breaker/stall engine
the MOST often occurrence of A/C damage is extensive runtime with low voltage shore power, something that does NOT "naturally happen" when using a generator
a generator under so much load it has "low voltage" is going to "fail" in some manner, as noted above
That was my thought. 1/2 sec of high amperage isn't likely to burn out anything. As long as it quickly recovers and holds a good voltage, there shouldn't be a problem.
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 28, 2026
