Monkeyrun's avatar
Monkeyrun
Does this valve disassemble?
Getting ready for our second trip, this time a bit further than the last, and in going over the coach I found one of the brass valves for the water heater bypass leaking slightly. I did attempt to back what appears to be the packing nut off without luck, seems to be frozen.
Before I apply more leverage to it, I just wanted to be certain that the collar does indeed unscrew from the valve body.
  • Hard to say from the angle of the photo. If it has a nut around the stem then I would assume it has packing. You can break brass valves by using too much force on them.
Having RV issues? Connect with others who have been in your shoes.24,194 PostsLatest Activity: Jan 29, 2025
