DutchmenSport
Nov 20, 2018Explorer
Water boils at 212?F. The water heater relief valve is set at 210?F. If pressure exceeds too much or if the temperature gets too hot to wear it will begin boiling the pressure relief valve will blow. So what you are hearing is not boiling water. It's just water being heated.
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 11, 2026
