jerryjay11
Nov 20, 2018Explorer
The key here is you turn the water pump on and the boiling goes away. If you WH isn't under pressure either from the water pump or city water supply you will likely hear water boiling because of air within the HW tank allows this to occur when not under pressure.
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 11, 2026
