rbts
Apr 12, 2018Explorer
donn0128 wrote:
Why do you want an inverter charger? Are you planning to run everything on 120VAC instead of 12VDC? In a RV 12VDC is much more convienent. You already have the battery, so use a converter charger of your choice, make everything 12VDC except the one or two things you think you want as 120VAC.
In a small RV like your RPod you will not have enough space to put enough batteries to run much on 120VAC.
The inverter is for the ability to run some AC appliances for short amounts of time while not plugged in to shore power (laptop charger/toaster/etc.) I know DC is far more efficient, but my goal is to make everything as versatile and painless a system as possible.
Having RV issues? Connect with others who have been in your shoes.24,406 PostsLatest Activity: Aug 14, 2026
