theoldwizard1
Apr 12, 2018Explorer II
rbts wrote:
Solar panels (wattage TBD)
Solar charge controller
Spartan Power 2200w inverter/charger (also includes a transfer switch): ***Link Removed***
AGM batteries (probably two 6V, haven't calculated my needs yet).
First, I think you are going in the right direction ! If you are going to have an inverter it should be the "hub" of your power distribution system. The built in transfer switch will make things easier. You might want to look at Samlex inverter/chargers only because they are designed to accept generator AND solar input directly into the inverter/charger.
rbts wrote:
What I'm stuck on is probably the simplest part of the setup, the distribution panel. Initially I had trouble because I didn't even know the right keywords to search for, and could only find residential sized breaker panels.
Check out Blue Seas Distribution Panels. Theses are marine distribution panels for both DC and AC. Probably a bit more expensive than typical RV panels, but they are well built.
The only 6V (golf cart) AGM batteries I have seen are Trojan Reliant T105-AGM. Not cheap.
Having RV issues? Connect with others who have been in your shoes.24,406 PostsLatest Activity: Aug 14, 2026
