j-d
Apr 02, 2015Explorer II
Chris can say with more certainty, but I wonder if you'd need to baffle the back of it so a convection is set up through the coils. The install instructions want very little clearance between coils and inside wall of the coach. I'd guess that another way would be to back it up close to a wall, or leave a fan blowing onto the coils.
But I don't think I'd want you to run an automotive battery charger straight to the 12VDC leads of the Fridge's Logic Board. An ordinary charger tends to run at too high a voltage unless loaded down/stabilized by a Battery.
sch - I've got a box of Warts and Bricks I about can't lift. But I've been able to save the day a few times, thanks to it!
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
