BFL13
Feb 24, 2019Explorer II
buylow12 wrote:
No check lamp is always off.
To be clear, it does not even flicker when first turning it on gas?
Mine has the two yellow lights, gas and check both on at first, then it catches (you hear it light and stay on gas) and check light goes out. When the fridge is turned off and then restarted on gas, it catches real fast so the check lamp just flicks on and off real fast.
Trying to figure if check lamp has anything to do with the flame sensor that does not seem to getting the word out that the flame is on.
On mine is the fat red wire from ignitor to burner and also a thin black wire to the burner, that has a connector along it. If that thin black wire is not connected, the flame sensor is disconnected, so I suppose it would keep sparking? (does not explain sparking on AC mode though)
Pulling the fat red wire off the ignitor board is not the same as pulling the plug out of the power supply board for that test.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
