Yankee_Clipper's avatar
Nov 17, 2017
Dometic RM2852 died
Working on the motorhome last weekend, and went for a cold bottle of water. Whoops, everything is warm inside the fridge and the freezer has water where ice ought to be. Looked in the outside access panel and there was the dreaded yellow **** all over the bottom of the compartment. Time to make some decisions.
We considered a small house fridge, and the ~24x24x60 opening, and there are products that will fit in the 9.5 cu.ft. range: but, they only work when plugged in and/or genset running. Plus, there is the issue of anchoring to the chassis, and securing doors and shelved not meant to bounce down a road.
I settled on a new cooling unit, and selected a remanufactured core from rvcoolingunit.com . David Force, the owner, was very helpful in ensuring the correct unit was ordered, because that Dometic model has gone through several modifications over its long production run.
I have drafted my sons to help with the removal and replacement of the unit and will report here on lesson learned. My wife has listened to my plans and expects to spend the day shopping in Tallahassee!
