joshuajim's avatar
joshuajim
Explorer II
Mar 26, 2017
Dometic 13.5 issue
I have a 4 year old Wildwood with a Dometic 13.5 with single zone thermostat. On my current trip, the unit keeps losing it's initialization. I am on shore power. It seems to occur at night (but we're not using heat during the day) and then I get the click, click click from the A/C. I hit the (+) (mode) wait 3 seconds for the 2 horizontal lines to appear and then hit (mode) again. This fixes it for a while.
This has happened a couple of days in a row.
Any thoughts?
  • Artum Snowbird wrote:
    Have a look at this site... let me know if it helps.
    Clicking
    Thanks for the link. It's the same issue but no resolution of the reoccuring loss of initialization.
    Oops, I guess I misread your post then. You said the click is coming from the A/C and it sounded like you were calling for heat with your single zone thermostat. I thought maybe you have a heat strip up above.
    Is the click coming from the A/C, or the furnace.. or the thermostat? Or maybe the thermostat is actually located on the A/C?
    The controls for the single zone are located in the A/C, and controls both the A/C and heater. The clicking is a common result of not initalizing the system and eminates from the A/C as that is where the control board is located. All the controls are low voltage. I don't know why it is "losing" it's initialization.
  • Oops, I guess I misread your post then. You said the click is coming from the A/C and it sounded like you were calling for heat with your single zone thermostat. I thought maybe you have a heat strip up above.
    It could possibly be loose wiring. When you are heating, the wiring if it's loose would create a high resistance point.
    Definitely check the positive and negative in your 120 volt panel, and tighten anything that appears loose.
    If it has only occurred at this one shore power location and not at any others, that might tell you something to. If everyone is pulling heat in the middle of the night, their lines might be stretched to put out sufficient for everyone, or their plug or your cord might have loose wires too.
    If you can put a meter on voltage when it's running to see if it stays up, or if it gets voltage drop from overuse, that would help too.
    The only problem with that theory is that the heater runs strictly on 12v.
  • It could possibly be loose wiring. When you are heating, the wiring if it's loose would create a high resistance point.
Having RV issues? Connect with others who have been in your shoes.24,359 PostsLatest Activity: Feb 07, 2026
