otrfun
Nov 01, 2015Explorer II
Dometic 13.5k a/c Inop
Cooled perfectly yesterday. Turned it on today--no-go.
Voltage in the TT is 120-122. 1500w microwave works fine with very little voltage drop, so I'm assuming incoming power is fine. For the heck of it I did try the 50a outlet, too---I still get the same symptoms:
A/c unit is non-ducted, with all controls and vents in the ceiling console. Fan works fine on all 3 speeds, but there's no cooling. With the fan on high and the thermostat set for maximum cool, something in the a/c is trying to "cycle" every 30-45 sec. for approx. a second--continuously, every 30-45 sec. When it does, voltage in the TT drops from 120 to about 114 for about a second. You can hear the a/c fan and another fan I have turned on change pitch slightly every times it cycles. Must be quite a bit of momentary current to drop the voltage like that--I'm estimating 20-25a.
I'm camping right now, with plans to depart tomorrow morning, so don't have a ladder or any test equipment except a VM. Bad start cap? Bad compressor? Any recommended tests/checks on the upper unit (or ceiling console) when I get home tomorrow?
Mucho thanks!
P.S. PI EMS has been on 24/7--no errors reported.
Mucho thanks!
