Chris_Bryant
Apr 08, 2016Explorer II
Should be fairly easy- it may be easier to remove some of the sheet metal, but IIRC you can remove it without disassembly- it's just a tight squeeze getting it out.
For the sheet metal it should just be a bunch of sheet metal screws needing a 5/16 nut driver to remove, for the fan just loosen the clamp and slide it off.
