joelc's avatar
joelc
Nomad
Jul 17, 2025
Dometic DMC4101 Problem
I have the above 12V fridge and the evaporator freezer fan stopped working.  Blue blinking light in fridge compartment.  From my searches I have found that this is either a fan failure  (4453000635) or the Control bd failure (4453000636).  No one has this fan in stock and I have been able to locate a Control Board. (Have tried like motors to no avail.) I have sent Dometic a message several weeks ago and have not heard back from them.  I have had some minor problems before with this unit but have been able to address them. The company does NOT support their products by having parts available.  I am almost at the point of chucking this 2 yr. old fridge and getting a Residential.
Two points: 1.   Do not purchase this product and 2, does anyone have luck with a Residental Fridge.....10 cu.  Model and make please.  I am a full timer, basically hooked up to shore power at my site most of the time.  It is a good thing this did not happen on the road.
I personally, will never buy another Dometic product other than the toilet I have which works well. (no joke intended)
  • I was able to fix this problem by replacing fan with one from amazon:
    https://youtu.be/bcinTAafTXk?si=uOYZ58lYg-UeAEg_
  • Add to first blog.  To Stircrazy:  If you owned this item and something went wrong you would change your tune.
    I do have a similar fan that I obtained with slightly different specs.  Don't know if it will work or not.  As far as the OEM fan I was told that Dometic does not have them.  In the mean time, I was in contact with Panther RV (Who has been great with me) and they DID get correspondence from Dometic.  I checked the Power Module (4453000609) and found a large scorch mark on it.  I am waiting for this part to come in and hopefully all will work.
    • StirCrazy's avatar
      StirCrazy
      Moderator
      no not really, I have owned enough rv's, and for long enough, to know there are issues with everything and if its out of warranty I am on my own.  sometimes you get good will from companies if you are not far out of warranty but not always.  it is a fridge model that is used in a lot of platforms so there are bound to be some with issues just from the shear number of them out there.
  • doing a search on the internet all I can find is how highly regarded this fridge is on review sites.
    I find it hard to believe that there are no parts available to purchase for a fridge that is still current, but having said that, ya a residential fridge would make more sense for you.  its a bit of work doing the conversion but you end up with more fridge space, well maybe not with a 12v compressor conversion.  but if you have an issue, you will have the same issue of parts shortages so be ready for that.  I found getting my house fridge serviced was way harder than the rv due to the parts shortages with LG, Panasonic and Samsung.
