dougrainer
Jul 08, 2013Nomad
Once the tstat is satisfied, the gas valve/tstat should then go to Low (pilot) flame. Yes, you can tell the difference. The BEST way to test is to operate on MAX cold setting on the LP tstat let run 24 hours and then in the morning before the heat gets to the RV, between 6 and 9 am, have someone turn the tstat back to the warmest setting while you watch the flame. You will see it go from full and then just a little lower for Bypass mode. Doug
Having RV issues? Connect with others who have been in your shoes.24,393 PostsLatest Activity: Jun 12, 2026
