riven1950 wrote:
Thanks so much for the replies.
Doug: Is the fan you refer to running all the time? If it is not running maybe my immediate problem. Maybe Dometic will repair it if that is the problem as our unit is < 2 years old. I am still planning on putting in the extra fans. Have read about them but never had a problem before, even spending a month in the Keys the first winter. Makes me think the OE fan is out.
Mitch: Do you have details on where I can find the fans and how to hook them up or point me in a direction to find that info I like the looks of your setup.
Your problem is the OEM install and Dometic will not fix/modify OEM install issues. What I do is, I tie the new 4 inch 12 volt fan power to that tstat temp disc. That way the fans only run when the rear heat reaches and closes the Tstat fan disc. The fans the other poster showed are great, but all you need is the standard 4 inch 12 volt fan. Doug
