dougrainer
Aug 24, 2016Nomad
1. I would run an external LP tank and hose direct to the refer and check for a few days. IF that did not fix the problem, then the odds are the Wire Harness between the rear Circuit Board and the inside eyebrow has a short or open circuit
2. If it fails as often as you state, WHY did you pick up the unit from the dealer if they failed to fix it????????? Doug
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
