dougrainer
Aug 24, 2016Nomad
ldrider000 wrote:
The dealer rerouted the propane line leaving the tanks so there are no kinks. The propane pressure at the unit is within specs. All the other propane appliances work perfectly.
I picked the unit up from the dealer because they thought it was fixed. I didn't know it was still malfunctioning until I got it home and could run it for a while.
Maybe the solenoid or thermocouple are bad even though they tested okay?
You state it constantly malfunctions. So, either you are nuts or the dealer is nuts. It HAD to constantly malfunction at the dealer if it fails as often as you state. So, as another posted, I have lost faith in that dealer. You can take to any Dometic Service Center for warranty work. Now, if it goes to CHECK immediately when turning on that is NOT a LP supply problem. It will only go to CHECK after a 3 times attempt at lighting or if lit and then goes out and fails to relight. Doug
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
