Old-Biscuit
Jun 04, 2015Explorer III
dougrainer wrote:
Taking the Thermister and just pulling it OFF the fins will allow the refer to run all the time. YOUR problem is, you DO HAVE a problem if the refer will not get colder than 45 degrees. You think the slider is a joke when in reality, your refer has a problem that needs professionally checked out, to find out why it is operating 10 degrees hotter than normal. Doug
YES......
But OP is just guessing at the temp....so really don't know if fridge is not properly cooling.
OP..you need to 'measure' actual temps.
Glass of water with thermometer in it........leave overnight and then check temp.
Have you checked backside of fridge for any obstructions to air flow/draft?
Have you checked the installation of fridge for proper set-backs/clearances/no dead-air spaces as recommended by Dometic (RV mfgs. don't always install fridges correctly)?
Any obstructions at roof vent?
HERE is installation/service manual that will detail how it should have been installed
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
