dougrainer
Feb 07, 2016Nomad
bbaker2001 wrote:
my dometic will get to about 38-41. when using refrig it creeps up to 43.
I was looking at manual and it says
In AUTO mode operation, the temperature is controlled by
a single temperature setting.
B. MANUAL MODE
When operating in the MANUAL mode, the AUTO mode
indicator lamp (A) will be off, and the refrigerator will run
continuously on the energy source selected by the control
system.
I do not have a manual option. only auto, and gas. when on gas I think it to would be controlled by the auto temp of about 40.
so if I want colder I can try the dino thermistor.
also when on gas it does not always re ignite and goes to check. is it difficult to change the igniter unit out.
What model number and year model RV? There is NO manual mode I am aware of on a Dometic refer in the past 20 years. The AUTO just means it will operate on 120 volts if 120 is available and will AUTO go to LP when 120 is NOT available. The LP mode means (or releasing the Auto button and it is OFF) just means the refer will run on LP all the time even if 120 ac is available. ALL modes are Thermister (tstat) controlled. Doug
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
