dougrainer
Feb 16, 2018Nomad
The Dometic was NOT as good as the Norcold 1200. There is NOTHING wrong with the Norcold 1200 in performance. The safety factor and recall have been blown completely out reason. IF I had a choice between a Dometic side by side or 4 door and a Norcold 1200/1210, I would opt for the 1200. The Dometic recall was for the exact same supposed problem and Dometic's was not as good and Dometic's covered ALL their RV refers, unlike Norcold, only covered the 1200 model. If you want residential and the unit is almost 10 years old, I would indeed install a Samsung. Doug
Having RV issues? Connect with others who have been in your shoes.24,367 PostsLatest Activity: Mar 10, 2026
