Gau_8's avatar
Gau_8
Dometic 5 button thermostat
I have a 5 button thermostat with two penguin hc units. As I understand it, the second unit must have a remote temp sensor installed. If you install a remote sensor for zone 1, does the thermostat automatically detect it and use it instead of the one in the thermostat.
The front unit is short cycling and the rear will not come on at all. It will run the fan in the manual mode.
Having RV issues? Connect with others who have been in your shoes.24,397 PostsLatest Activity: Jun 28, 2026
