RoadRose's avatar
RoadRose
Dometic 8500 manual awaning
Has anyone experience with a dometic 8500 manual awning? If so, can one person actually operate? Thanks
NOTE: Did you see the "Announcement : ★★READ BEFORE POSTING HERE★★" located at the top of this forum?
    "Forum Posting Help and Support is reserved for questions on how to post in the forums, signature and photo testing, reporting website or member account issues. Please avoid using Forum Posting Help and Support for RV related questions, as doing so can delay responses to your thread. Instead, create future threads in the RV FORUM which corresponds to the subject of your topic. Thank-you!"
  • Chris Bryant wrote:
    You just need to remember to have the awning wand when you roll it up, or you get stuck letting it slam against the trailer. Fine awning, what I would buy if looking.
    Great advice and IMO not so much about it slamming against the trailer, but unless you hold onto the pull strap until it's completely closed the loop on the end to use the wand to open it will be tucked somewhere in side the awning and not accessible. Then you might need two so you can pull on the arms evenly to open the awning the next time.
    Larry
  • i don't see how i would have needed a second person, to open and roll out the 8500 awning on my previous TT.
  • You just need to remember to have the awning wand when you roll it up, or you get stuck letting it slam against the trailer. Fine awning, what I would buy if looking.
  • Sure. Did it all the time hy myself. You just need to get in a routine.
