- ron_dittmerExplorer III
YWORRYDOG wrote:
Thanks, Ron, just what I was looking for. - YWORRYDOGExplorerThanks, Ron, just what I was looking for.
YWORRYDOG wrote:
If I were doing what you are doing, I would plug the holes with plastic rivets that look like this.
.......and idea on how to plug the holes?
They can be bought in various sizes and colors, most common in black at auto part stores, and white at home improvement centers. Buy ones as small as you can get away with. You might have to drill the holes bigger or cleaner to get the right fastening action. I would also add a lot of clear silicone caulk inside the hole and the inside of the pin so it oozes out when pushed in. Then wipe clean for a perfect seal. - YWORRYDOGExplorerThank you all that is what I am looking for, and idea on how to plug the holes?
- j-dExplorer III like manual because of the simple mechanics of it. So manual would be my choice initially, and if I had an electric that needed both fabric and motor, I'd replace. And live with the patched-up holes.
BUT! I've come to realize that sliding the weight of a manual awning out to deployed height can be a strain for many. Ours is a 21-foot Carefree and 21-foot makes it heavy. Smaller awnings might be OK, but I'm not sure I'd want to or even be able to deploy it a bunch of years from now. So be sure you're OK with the physical aspect of a manual awning. If you are, go with it! - IAMICHABODExplorer III
YWORRYDOG wrote:
please, I am not looking for pro or con, my elect has a bad motor, and the fabric got damaged in Alaska. This is the 2nd motor, and cost is $450. for the motor alone. I want to know if anyone did it, and how much damage in removing the old one. I know there will be some holes where the elect one is mounted to the side.
Here is someone that did it.
Link to that post - DakzukiExplorer II
Just curious. What brand is your awning?
Yes, it can be done BTW (no, I haven't done it) on an externally mounted one. A recessed one would be more problematic (like Bigfoot RVs have) when changing awning types. Unbolt old awning hardware and install new. Some filling of now unused holes and drilling new ones may be required. If you take the plunge, get a good one if you are planning on keeping the RV for a while. - ronfishermanModeratorYes you can replace it. From GR I would drive to down to White Pigeon and pick up the parts needed to replace/repair a awing.
3 places to try.
Johnsons Surplus
Toms Borderline Bargins
Bontrager's Surplus
A couple in Elkhart.
RV Part Nation
Factory RV Surplus
There are others in the area. But these are the most popular. All but Toms do shipping.
Also check Ebay. Lots of awning parts offered there. - YWORRYDOGExplorerplease, I am not looking for pro or con, my elect has a bad motor, and the fabric got damaged in Alaska. This is the 2nd motor, and cost is $450. for the motor alone. I want to know if anyone did it, and how much damage in removing the old one. I know there will be some holes where the elect one is mounted to the side.
- K_CharlesExplorerWe were used to the manual awning and missed it when we got the electric on the last TT. When we finally started liking it we got a MH with a manual. We don't miss the electric. They both have there good points.
38,782 PostsLatest Activity: Sep 02, 2026
