Chris_Bryant
Aug 27, 2017Explorer II
It sounds like the cap tube for the thermostat is not positioned correctly. Remove the filter, and you should see the silver tube coming out of the control box- it needs to be positioned in the return air stream- IIRC, there is a small holder with a plastic grommet it needs to be in.
I have seen the tube stuck in the coils, which doesn't work.
That thermostat should be fairly adjustable and accurate, once you find the right position for it.
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 13, 2026
