j-d
Aug 27, 2017Explorer II
You have two control knobs, right? One is the Temperature Knob. The other is a Switch with say Off, Low Fan, High Fan, Low Cool, High Cool, right?
I'm just guessing here, but couldn't you put a relay in place of the Temp Knob then a wall thermostat with appropriate control voltage for the Relay? The A/C Fan would run (should always be on HIGH when using Cooling!) full time, then the Compressor would cycle based on the new wall thermostat.
Now that I've said that, wondering if I could do that on our Coleman Mach...?
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 13, 2026
