Charlie_D_'s avatar
Charlie_D_
Dometic AC 15,000 BTU
When running my compressor will drop off and immediately restart. Happens randomly and inside or outside temps do not seem to matter
Thermostat is Dometic digital set on AU. Fan motor continues to run. Fan speed does not change. On start up fans runs a few seconds and then compressor comes on. When temps satisfied compressor shuts off, fans runs about 5 seconds and then shuts off. Has 2 capacitors, neither show signs of leakage. 50 amp unit running on 30 amp cords and voltage when running is 118. Does not fluctuate.
Any ideas?
  • As far as I know it's normal for the newer units. Both of mine do it.
  • Is it freezing up? Take the filter off the inside and look at the little radiator looking thing.
