dougrainer
Apr 18, 2021Nomad
Tjpries1 wrote:
Thank you dougrainer for your help. I was able to get the ac and the furnace both working. I simply hooked it back up but left the one white/orange ,the one that must be shorting out, disconnected . Since I had two of the 12volt - wires . I checked and had 12 volt, not really sure why they have 2 of the same wires, you were right the control box was good.thanks again for walking me thru the process !
There are EXTRA wires that are NOT used coming out of the control box. You have Red Pos IN from the fuse supply. You then have a Pos output to the tstat. You found that someone had combined 2 wires and should not have and should have had a wire nut installed to prevent shorting. SOMEONE had to have combined those wires or you would have had this problem from when the unit was new. Doug
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
