2oldman
Dec 27, 2015Explorer II
LaunchnRetrieve wrote:No, that's not normal, if it's both a gas and AC fridge. As said above, take off the back panel and make sure the ac plug is in. Push the Auto/gas switch a few times.. maybe it's stuck. Try turning the unit off and on a few times.
Regardless it will always use propane?
Mine got stuck on ac once, I finally had to pull its ac feed plug to get it to go to gas. It's plugged back in and working ok. Sometimes they get confused!
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
