enblethen
Dec 27, 2015Nomad
No it should not always run on propane. When the refer is set it should run on AC if available and run on propane when not available.
Refer should be set on "auto".
Start by checking the refer receptacle in the exterior access. Use a known good appliance such as an electric drill. Wiggle the cord body in the receptacle while operating the appliance to see if it cuts out.
Check the fuse holder on the circuit board in the refer outside access.
Turn off power to the refer or the rig. remove the circuit board and inspect the back of it for burnt places. If you see any replace circuit board with Dinosaur Electronics replacement.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
