dougrainer
Feb 19, 2019Nomad
Great Flame means nothing. You need to verify LP pressure at 11.5 inches. As the other poster mentioned, if the spiral baffle has rusted or deteriorated after 20 years, it will NOT dispurse the flame/heat for the boiler tube correctly. The only way to determine the baffle is to pull the refer and pull the spiral out of the chimney. Doug
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 04, 2026
